Thrashercharged
I have a Mariner Magnum II 150 / Merc XR4 2.4L that doesn't have spark in any cylinder. The trigger wheel and stator ohm out to spec. I've verified with a scope that the trigger wheel is good and the stator is outputting the correct voltage; it appears that both CDI Switch modules are dead. I find it odd that both are bad so if possible, I'd like to try to test each module independently.
The pics show the scope traces of the trigger wheel and the white/black wire. On the V6 it connects between the 2 CDI switch modules and I've heard it referred to as the "Bias" or "balance" wire. On the 3 cyl with only a single CDI Switch, it goes up to the trigger wheel.
What's this white/black wire do exactly? I figure the modules are the same between the V6 and the 3 cyl, so it's puzzling to me how that same terminal can connect to the trigger wheel on the 3 cyl and between the 2 modules on the V6? I did disconnect the black/yellow kill wires and all wires look good.
Note: I posted this question on Bassboat Central earlier but figured I'd get a wider audience here and better chance of getting an answer!
