centerline
I have this 850 that I disassembled and freshened with new rings, restrictors, upper and lower main bearings, new gaskets, new spark plugs, carb and fuel pump rebuilds, with all new fuel lines...
it is a 1975 merc 850, the specs call for 2-5 initial advance, and 27 max advance.. I have it within the specs
after learning how to set up the carb/advance sync, I have gone over it several times to set and reset and to insure I got it right and havent missed anything.
it starts a bit hard, but otherwise runs great and idles absolutely smooth, but for the life of me, I can not get it to stay running when shifted into gear in the test tank... on the muffs the problem does not show itself..
the flywheel and distributor gear are in their respective positions....the pickup advance is set to 3btdc... the max advance is set to 26btdc.... the idle in neutral is 950 in the test tank.... the prop is a thin bladed 17pitch... the gas is NON-ethanol, mixed as close to 50:1 as possible.
I have adjusted the carbs to max rpm using a TA100 smart tach to get the highest rpm from the motor, and found that to do this, the screws arent adjusted the same amount of turns out, but withing 1/2 turn from each other... the engine idles smooth without a hickup..... as i turn the screws out another quarter to richen it, the engine idles rougher and there is a bit more smoke from it.....
I have tied shifting it into gear, at all possible carb settings, and it tries to run, but it immediately begins to run rough or misfire, and then dies... what else can I do?
would turning the distributor gear a notch clockwise help?... or counter clockwise?... maybe new plug wires?.... a higher or lower initial advance?
where do I go from here? Thanks Lou
