kerry_smith
"I replaced the ignition syste
"I replaced the ignition system on my 1954 Evinrude 25hp ob motor two years ago.(plugs, couls, condensors, points and rebuilt the carb.) I lost spark about two weeks ago so I replaced all of the above again. I noticed the travel of the points was not as far. The points are about half the gap (.020) that they were, now about .010. The spark is there but weak. The old points have the same issue after re-installing. If the lobe on the top of the crand shaft that moves the points is gone then what...duct tape? Any ideas? Compression seems to be fine although not verified I don't understand how the lobe on top of the crank could have wore down but the crank shaft still appear to be fien."
