Well.....We were having a nice first ride of the season (in july...long story) Boat is running great... Just replaced alternator so i am watching gauges......after about an hour i look down.....temp has gone from 120 to 220/230 in matter of minutes. I was idling at the time to go under a no wake bridge. i idled back to the launch and pulled it out. Boat continued to run fine.....temp did not continue to climb. I had to reverse at the launch cause of wind so I can't tell if i picked up some sea weed or something....but prop was clean...so i very much doubt it. I will refloat today and start and see where the temp goes. If it does what i suspect......and climbs again.....then the next question is where to start. It looks like to me we have two water pumps....one on out drive and one on motor.....which is most likely? how do I isolate the porblem to one or the other? How much hassle is it to change the outdrive water pump....do I need special tools? I can usually do most mechanical work if it doesn't get to techinical.....Frustrated and need some advice. I have gone through tilt motor problems....then to find out I had a bad alternator.....now this....All for a boat that has 160 orginal hours.....Not to mention that my "at home supervisor" aka the "wife" is starting to loose faith in the Cozy Lady....
