mashed_finger
Hi all..., I'm back, it's been awhile, and things have changed some on the site, still though, it's the best fix it forum around! First off, I have a 1992 OMC cobra with the 5.0 ford V8. I have been throwing parts at this sucker like crazy. Been having what I thought was an overheating problem, so I tossed parts at that like a drunken sailor. So I took it out today and it appeared to heat up to about 200-210 degrees, so I came home and had a brain fart of an idea. I have a fancy little hand held multi meter that just happens to have a temp setting with a nice little skinny wire probe. So I yanked off the big "U" tube and stuck the probe down the inside and put it back on the engine. I started her up and got up to the same high temp with muffs on, as it did at the lake. Long story short, the hand held multi meter read only 153 degrees, while the boat temp gauge read between 200-210. It would appear that I have a faulty gauge.
Question I have is, the gauge has an o/d of approx. 2 3/8" dia., Which are the good and very accurate brands to buy, and do they come with their own senders? THis problem has been worrying me sick, since I just put in a new Mallory magnetic pickup distributor. How hot is safe for them to get, I measured the outer case at around 138 degrees..., just wondering.
I also got the old Holly single pumper 600 cfm rebuilt (marine), I am kind of sorry I did, as it cost me a months liquor budget. I am having a hard time getting it to idle, just when I think I have it adjusted, when I come off plane, the idle is too high. When I shut off the key and restart, it either idles normal or too low..., and yes, I just put in a new CDI ESA, which seems to be working normally. This is making me crazy, I was told that fixing a Holly is a waste of money, and that I should just go and buy an Edelbrock..., I hate it when I am wrong...., good thing I am not a gambler.
As usual any help from you experts would be most appreciated. I won't be boating much the rest of this month, the tub goes in for an all new interior, with new rear bench and captains chairs...Ka ching. Thanks for the help in advance.
Rick
Rick
