Greetings all, I am new to the forum and need some help please. I recently bought a used BF75AW LRTA. When I changed out the impeller, I noticed that 2 seals were missing: #15 19253-ZW1-B01 and #11 19253-ZW1-003 as shown in the diagram. I ordered both parts. The small rubber seal attaches to the impeller housing outlet hole. The #11 part is a plastic cylinder about 1 3/4 inches long with a 1 1/8 inch diameter. It goes above the rubber seal. It looks like the plastic cylinder should attach into the extension case above the rubber seal. The inside of the cylinder has a rubber lining with grooves to hold it onto whatever it attaches to. Each end is slightly different. I need to know which end it up. Any help would be appreciated. Thanks.
