Water pump impeller
This is one where the key sits in a little notch in the side of the shaft ?? ( some are pins through the shaft.)
Hold the key in its notch in the shaft and slide the impeller down the shaft into position.
Make sure you use the correct key for the impeller.
Do you agree Joe
