I have an older 15hp Honda outboard that usually runs like a top. Yesterday I started it in my driveway with mufflers on and within a few second water spat out the tell tale at a decent rate. As the engine warmed, however, the water slowed and stopped.
I have checked the impeller, it seems fine. I have blown air through water pipes and can't find any plugs. Have checked for a plug at the spout. I started it again and the very same thing happened. Now I've pulled the thermostat and while it looked a little grubby it wasn't too bad - and it did work properly when I put it into a bowl of hot water.
Essentially the engine draws and blows water when cold, then as it heats, the water volume gradually reduces to nothing.
I'm no mechanic and sure will appreciate some advice. Thanks
