In the process of changing my
In the process of changing my starter I decided that I should go ahead and put new spark plugs in. Facing the engine working on the left. The very back plug looked alittle wet. The second plug from the back looked alright. Finally the plug closest to the front of the motor on the left side. When I took that plug out water drained just like I would have took out one of the plugs from the block. That cylinder I checked compression. It was 180. So I think thats good. A problem that I have been having is when I go full throttle really fast it wants to bog down. I can slowly open up the throttle and it will do fine.
I think I found the problem sort of. But I have a feeling that I already ruined my engine. Haven't check the dip stick to see if water actually seeped into the bottom.
Please Please Please What advice can you give me. As much as I don't want to I have to tackle this problem myself. I just can't afford that $90 a hour the boat shop charges. + whatever parts cost.
Thanks you guys are awesome
