sturgeon_general
I have a 1983 ,25 hp,Evinrude,model#E25RCIM,that has a leak I think around the bottom gear housing case cover or around propeller shaft.The propeller shaft from a visiablly veiwing doesn't appear to be bent.My question is it possable to remove the bottom gearcase cover and replace the spagetti seal without the gears and associated parts moving or shifting out of alignment,because I've been told you don't want to deal with this part of the engine if you are not experienced or have any knowledge of this area of the engine,or don't have patience and have a short temper or frustratition level!!Any advice or info would be greatly appreciated thank you,"The SturgeonGeneral".
