Hi, I purchased a used boat at auction that came with a 2017 ProXS Verado 200. The engine may have been submerged in water as it was in a grounding. The engine turns over and the compression is good. The oil looks good. There is no evidence of water intrusion EXCEPT there is moisture in the electrical box leading me to believe the ECU has water damage. When you hook up electical the hydraulic lift pump that operates the tilt runs continuously. Would you all advise I try and get this ECU fixed? Replaced? Should I try to sell this enging to someone who wants a project and repower?
