oaklandaviator
"I pulled the outdrive off of
"I pulled the outdrive off of my pre-alpha Mercruiser in-line six powered unit. There was water and greasy goop all in there and the gimbal bearing was shot. I have installed a new gimbal bearing and oil seal and am having a couple problems:
First: the old bellows looks to be in good shape, although I don't know how old it is so I'm going to replace it (parts on order). I am also going to replace the oil seal on the shifter shaft because it looks like water could get into the bellows area that way. Are there any other ways water could get into the bellows area since the bellows actually appears to be in good shape?
Second: How do you get the bell housing off of a pre-alpha drive in order to change the bellows and water hose? It doesn't appear that the Mercruiser "special tool" for the Alpha will work on my drive. Thanks for any help!"
