ok let me start of by saying that i am a newbie to boats as i just purchased my first (1988 sunchaser deck 1702 with a 3.0L and alpha 1)i bought it cheap enough knowing that it had "a cracked block" now i do know a little about motors as i a lot of my own maintance on my cars...got the boat home took a 55gal drum layed on its side cut a hot in it big enough got the outdrive to fit in filled with water hit the key after a few turns she fired up what i noticed next is my questions first of all i have water coming out from under the manifold and i dont mean a little you probally could fill a 5 gal bucked in no time what could it be??bad manifold? blown head gasket? blown manifold gasket? some one suggested water pump??any thought
when i hopped out of boat and looked at the out drive it had water oming down from somewhere hitting the outdrive but i went a head and shut it off shortly after that now it did not want to idel but if you gave just a little throtle would purr just fine and rev right on up i did check the oil in it first and noticed that it was still kind of carmel color but frothy looking so i am thinking that it has a little water in it hince the blown head gasket any thought and input would be greatly appreciated and thanks in advance
