Vro pump
joe_k
"I disconnected VRO pump but a
"I disconnected VRO pump but alarm is going off, if I disconnect alarm will that affect rest of engines sensor's"
"nope---just un-hook VRO wire
"nope---just un-hook VRO wire plug....while u r thinking sensors,..ck ur hot horn ones..what engine?????"
"THANK YOU FOR INFO, DO I DISC
"THANK YOU FOR INFO, DO I DISCONNECT FROM HORN OR FROM PUMP ? ITS A 1993 JOHNSON 200 OCEANRUNNER"
wires from the pump.NOT THE HO
wires from the pump.NOT THE HORN.
yes follow mfr procedures for proper break in
make sure you cap off the oil feed line or you
will have more problems
"disc the vro wires,at the plu
"disc the vro wires,at the plug that leads fr vro,10" or so....absolutely do dbl oil,do not use syn for the brk in period."
"okay motor guys I have a 199
"okay motor guys I have a 1993 JOHNSON 200hp on my "79"-20'ccp its hard starting when finnaly warmed up put in gear and dies a couple of times then goes,runs great, bring back to idle dies what could it be ?"
