"Hey all,
Motor is a 1988 120
"Hey all,
Motor is a 1988 120 Looper VRO V4. We have owned it now for almost 2 years. Based on information from this site, the VERY FIRST thing we did (2 years ago)was remove the oil tank, and bypass the VRO system, and we mix our own oil in the gas tank. We have used it darn near every single weekend since then for 2 years and has run flawlessly. We DID NOT change the VRO/Fuel pump at that time, although some recommend that you do...saying that it would go out if not...which I think it did!
Today, we took it out to the lake, it started normally and idled in the marina while I parked the truck. I get picked up at the dock and we idle out the wakeless buoys then roll on the throttle. It accelerated normally and once up on plane I backed off to just under full throttle as I normally do. It ran great as usual, 4000+ rpms or so for about 20 seconds...then died like it ran out of gas. We have an auxilary motor on this boat (one tank, with a switch that goes to the main motor or aux motor), and we thought that we had not switched the fuel switch back, as that was the symptom...it just seemed to run out of gas. Bulb was VERY FIRM and could not pump it anymore. Pulled the fuel line from the engine side of the filter and pumped the bulb, fuel squirted out just fine. We then disconnected the fuel line from the TOP of th VRO pump, and we hooked the fuel line directly to it, pumped the bulb and the motor started right up. Will idle as long as we pump the bulb every now and then. Tried to go fast that way but we killed it...either not enough bulb pumping or too much. Anyway, while idling it has a definite TICK TICK TICK from the VRO pump (almost a CLUNK CLUNK CLUNK).
I'm thinking the fuel pump went out. But I'm worried about the TICK TICK TICK. Also, (I haven't searched yet), seems there are 3 pumps available: Original type, which is not desirable (brown fitting...what we have), the UPGRADE VRO pump, and a PLAIN FUEL pump.
Since we mix our gas and oil, do we want to buy the PLAIN fuel pump? I would appreciate some help in what to order for this. Also, any chance it is something other than the fuel pump? Anything that can get restricted between the pump and the carbs?
I have the SELOC manual, but haven't dug into yet...just got back and wanted to get the best information from this site!
THANK YOU ALL in advance...I hope you can help me!
Randy"
Motor is a 1988 120
"Hey all,
Randy"
