Hi, I really need some help to solve an overheating problem on my Four Winns 225 Sundowner. The power unit is VP 5.0 GXi-D with Duo Prop, sea water cooled, has approx 300 hours on.
The engine runs well, and does not overheat below 2000 RPM. However, above 2000 RPM it seems to overheat, the gauge goes right up and the alarm sounds. When I back off and try to accelerate the engine will not increase revs, so I assume it enters limp home mode.
There does not seem to be any evidence of it actually being hot, with an infra red thermometer on the thermostat housing it only reads approx 162 degrees fahrenheit. No steam, no burning paint, doesn't smell hot etc. All hoses look good inc. the rubber hose from drive unit into transom.
Ive experienced this fault since the engine was serviced. 2 spark plugs had corroded in starboard head and so the head was removed so to they could be removed and replaced. Its had new plugs & leads, new fuel pump, temperature gauge, temperature sender, water pump, thermostat, impeller, starboard exhaust manifold. (as old one was corroded) New impeller has been checked and is fine; the starboard riser was clear when head was removed and exhaust manifold replaced.
Water pump does not feel hot when engine has overheated.
Overheats when its on the plane or not on the plane, but only at over 2000 rpm.
Does not overheat when in neutral and being revved to 3000 RPM+
Any ideas what could be causing this, really struggling to know what else to try. Boat is in the UK and used on the sea; its kept on trailer and flushed with fresh water after every use. Starts and runs fine, apart from this!
Thanks for reading and if you have ideas please take a couple of mins to give suggestions.
