Ibought a 2001 Seafox with a 3.0L Volvo penta outdrive.It was shot so I replaced everything except the motor with mercruiser.It has now got a water pump impeller and a raw water pump that was on the motor.My problem is it builds up to much pressure and blows off the large U shaped water hose. Like it needs to flow more water out. I removed the impeller from the raw water pump but now it runs 170 degrees at idle(it ran 125 with both pumps) and still blows off the hose anyway as soon as the throttle is increased. At idle the large hose is under so much pressure it can't be colapsed by hand. Not sure why this is happening.
