I installed a new to me engine in my boat and I need to know how to align the engine. I have installed engines in OMC cobra and Mercruiser where you stick a alignment tool through the transom into the engine coupler and raise or lower the engine mount until the alignment tool slides in and out freely. On the Volvo 290 there is a short spline shaft that slides into the flex plate on the flywheel. Once I got the splines lined up it slid in. The bellhousing bolts up to the inside part of the outdrive. I thought this was almost to easy (it only took about 2 hour). Now I am trying to get the alternator on and it looks like the front of the engine is to low because the tension bolt hits the stinger see pictures. The engine I removed was a Chevy 305, new engine is a Chevy 350 I assumed the block is the same size?
