I have a solex 44pa1 carb on an AQ125a the engine is a fresh rebuild and so is the carb. The boat runs fine at idle but when you accelerate it wants to die and sometimes backfire as a result of struggling and too much fuel going in. I do notice a flat spot with the carb. I was reading the factory manual and it said carburetors with main jet 165 and venturi jet 190 should have the spacer installed. with a gasket on either side.
So I took the two jets in question the venturi has jet 180 and the main jet is 155. Does this mean I need to remove the spacer with the restrictor on it and will it eliminate the flat spot. If not what position is that plate supposed to go. I assumed its with the arrow pointing towards the front of the engine and the wording up of course.
Anyone got any ideas I want to fish this weekend and don't want to have to idle to my fishing spot. Timing is fine and I have the pertronix kit installed.
Both the engine and the head are date stamped in 1983 or 1984
