Hi all, Hope you can help me with my problem. I've got 275 outdrives on AQ131A engines. When i select reverse gear the out drive bangs loud. Its also really stiff to select reverse and a couple of times i noticed that when the throttle lever was put in the reverse position, the drive was in neutral. i then put the leaver back to neutral and then back to reverse again and "Bang!" once again. When it was out of the water the reverse lock collar was stiff so i freed it up with some wd40 and that made the Fwd/Rev selector move freely, so i dont think its any of the linkage from the throttle to the out drive. I didnt try it with the engines running until i got it back in the water. Its back in the water now and i still have the same problems. What do you think could be going on , Mark
