I recently changed the drive oil in a 1986 Volvo 275 for the first time in 6 years. I noticed that the oil had a shimmering in the sunlight. There appears to be very fine almost powder filings in the oil. There were 4-5 very small metal flakes in the oil as well approximately 1mm in size. The larger pieces were ferrous however it appeared that the fine metal may have been aluminum. The boat runs well but I am worried there is an underlying issue. I ran for an hour or so and changed the oil again to flush. There was mostly the same condition with the oil the 2nd time. I plan to check it again after running for a week. By the way I am using 10-40 synthetic motor oil in the drive. I noticed that I can hear the gears quite loudly when I spin the prop by hand right above the lower gear housing. Is this normal and does anyone have any advise for me?
Thanks, Jason.
Thanks, Jason.
