Thank you very much for the reply, i will check that out today, should i take the feed line from the carb, and turn over the motor to see if the flow is good, and where is the anti syphon valve locatedCheck that the gasoline is reaching the carbs, you may have a stuck anti-syphon valve in the fuel tank.
How fresh is the gas?
