Thanks Jon. All that is good.Hi
For starters.
Make sure your idle speed is set correctly. Try to set it as low as possible without stalling.
This might not be achievable with a computer controlled motor.
Check the drive lube for water and make sure you are using the correct 75w90 GL5 synthetic lube without limited slip additive.
Jon Allen
