Bob
Noticed Vibe around 1600 rpm*which is a nice*8mph for us.Notice it at higher rpm also.Before doing any adjustments I ran each engine by itself to 1600 rpm,port side very smooth,starboard some vibe.Engines run smooth no matter what rpm,props were*suppose to be new 3-4 years ago when we bought the boat and to date no dings or chips,cutlass bearings good,have not checked shafts.Engine mounts in good shape.Then I checked alignment,starboard needed to move to port which I did,now runs smoother,when checking the gap stayed the same all when rotating shaft always a gap on left side of couplers.Still get some vibe*when running both above 1400,seems smoother around 2000 to 2200.Then notice above that again.Notice the vibe around the cockpit,nowhere else.Do not have a syncronizer so I used a laser tach and found both to running within 15rpm of each other@ 1600rpm
Regards
DP1
