Following up on my posts about high temps on starboard 454 where gauge showing about 183-185 degrees at 300rpm cruise (never measured at T Stat). So went back down yesterday and did the following:
- corrected/replaced gasket in water pump
- fixed output hose on pump - hard to see and 2nd hose clamp was
tightened on hose not over fitting
- opened and cleaned heatxchanger
- replaced thermostat with 160 deg t stat (dont knwo what old was)
Anyway to tell what the old thermostat is? Only markings are on bottom and say 17 J7 and VI42?? Also noticed if look inside from top new one has 2 rivets and one hole open, where old one has 3 look like rivets no hole open.
Then ran boat for 45 mintues at varying sppeds as well as start and stop, usually cruise at 3100, water temp was 89 degrees. Results were:
3000-3200 rpm - 21-22.6kts, P=13gph/S=14gph
Port temp: Gauge 168-172 / T Stat housing - 172-178
Starboard Temp: Gauge 172-175 / T Stat 176-180
3400 rpm - 25.3 kts
Port temp: Gauge 172 / T Stat housing - 174-176
Starboard Temp: Gauge 175 / T Stat 177-180
On returning to dock a few other measurments:
At 1100 rpm after coming off plane and long run:
Port temp: Gauge 161 / T Stat housing - 171
Starboard Temp: Gauge 170 / T Stat 175
OIL pressures running at Gauge - P=33 / S = 35
Back at dock took a few other measurements:
Coolant tanks - P=154 / S=162
Manifolds - P=163-165 / S= 168-172 is this a little warm)
T Stat - P=168 / S = 162
Elbow/Riser - 125-135
On taking readings at the thermostat housing I did notice they were consistently 5 degrees higher than the guages. It seems the Starboard motor may still be a little warm at low speeds. Any thoughts here?
Generally think am happy with the readings and seems within range. Any input would be appreciated, thanks ALL for the assitance!
3400 rpm - 25.3 kts
