bill murrin
replaced head gasket..."blown out" around edges...but still had 135 lbs compression , now @ 142 on both cyl's.....and runs cool again !!!
REPLACED new factory flywheel key.....my timing was at 19*( wot)....now idles @ 4*(btdc)...at wot only goes to 8*.......can move advance by hand, but will only go to 8*,with adj. screw turned completely out. using dial indicator on #1 cyl. , dial out to 19* , flywheel showes it @ 8* btdc.......question : how can the timing change by just replacing the flywheel key ????...need to know how to advance timing ? ? ? ?
