"Can anyone give their thought
"Can anyone give their thoughts on my problem. I have acquired a 19' Baretta with a 470 Mercruiser. The motor idles great but I clearly have a cooling problem. I can't get water thru from water inlet on bottom of foot to comeout of the pipe going from the outdrive to the heat exchanger. So I'm pretty sure I need to put a raw water pump on it. I can however get good water flow if I backwash it. My question: Will a water pump usually cause a tinging noise or could that be a more serious problem. When I put the outboard in gear it spins the prompt fine.
I was told the boat setup for 2 years inwhich prior to that the motor had been rebuilt.
Also, any quick fixes to a carb problem that runs fine at idle and part throtle but backfires and trys to die on acceleration. I think I have a mercarb 2 barrel but wonder if the accelerator pump is a typical problem. I don't think I see any fuel pumping out inside when pressing throttle down."
