Motors are 2003 carbed 300HP Crusader small blocks... 462 hours.
So.... I went to start the boat after layup from the 11/12 winter. She coughed and sputtered and fired for a second on both motors then nothing... WTHeck?? I knew I was burning off some fogging oil so I used a small amount of ether and both ran for a few seconds and died... Hhhmmm.
So I check to see if I'm getting any fuel by checking for a squirt from the accelerators pumps... nope.. Weird. I also didn't hear the electric fuel pumps running and DID have oil pressure showing on both motors so they should be running!!
Now the weird part.... both fuses are blown on the electric fuel pumps!! Again, WTH? I put in TWO new fuses and they both blow. So I disconnect the fuel pump electrical leads at the pumps, put in new fuses, crank the motors until I get oil pressure, and they don't blow!
I'm having a hard time believing I have a double fuel pump failure on separate engines but have no other explanation. I now have TWO new pumps on order but just can't believe this is possible! (it sure is very unlikely)
What am I missing? Did ethanol / water kill these pumps (boat was running GREAT when I wrapped up in late November)? Is there some other explanation?
Stumped,
JD
Stumped,
JD
