spahrticus
Alarm sounds don't match descriptions in Seloc manual. Have the sounds changed with VRO upgrades or are sounds dependent on the alarm itself? (Do not know if this is original alarm for boat or it was switched at some point. It's an '85 and I just bought it this spring.)
What I have found so far:
Constant alarm means over heat unless it goes away when you throttle down, then it can mean a fuel restriction, except that should only be on V6 and I have a V4.
1/2 second alarm every 20 seconds means low oil on original VRO.
10 second alarm can mean low oil or no oil on VRO2, again, do not know if part has been switched out. My motor is a 1985 90HP VRO V4 Evinrude and should have VRO as original part.
I did find two references in the forum that the writer assigned to indicating a bad VRO. One described an alarm that alternated 1/2 second on and a 1/2 second off, while the other described 1 second on and 1 second off. My issue was an alarm that was two seconds on and two seconds off. I took a gamble and replaced the VRO pump. During the oil prime test I got an alarm that was pretty much 1.5 second on and 1.5 second off. I went ahead and connected the oil line and alarm does not seem to come on. (Have not lake tested yet, just a hose in the drive way, but idled a lot longer than was necessary to get alarm previously.) Hopefully this means my issue is resolved, however, why did I not get the no/low alarm as described in the manual?
