You are very welcome.
OK... since you have the A drive (as in 275A), the BB will be an intergrated aluminum BB.
All transmissions including and after the A are this style.... 275A, SPA , DP A, DP B and so on.
This means that the bearing pre-load will be crush sleeve controlled... (i.e., no shims within the seal surface washer).
You can replace this seal surface washer without affecting the rolling torque (unlike the earlier transmissions).... but the catch is..... the sleeve "crush" will affect the rolling torque value.
The book will suggest that a new crush sleeve be installed.
However, if you are careful, the crush sleeve can be reused by slilghly increasing the rolling torque value.
The OEM service manual will give us rolling torque values for both "new" and what they call "run-in" bearings (i.e., used and re-usable bearings)
This means that the original crush sleeve will be further compressed, but not by much.
That's the key if you are to do this.
If you can't make the value, then you will replace the crush sleeve and begin again.
You'll also see inch pounds and circular string line rolling torque procedures mentioned.
If your specs suggest spring scale values, then use a string line and scale.
String line/spring scale uses the BB circumfereance as the means of load point to roll the bearings.
If your specs suggest inch pounds, then the inch pound torque wrench procedure must be used.
Inch pounds uses center rotational force to roll the bearings.
DO NOT confuse the values between these two methods... they will not render the same rolling torque values if confused.
Being an A transmission also means that the BB shims are a gasket style shim between the collar and the main gear case.
You will be able to R&R the BB without any change to gear pattern unless you were to replace the two tapered roller bearings.
Even then the change would be minimal, but must be checked.
Use sealant on the four bolt threads.
Bring all four bolts down together until the gap closes to about 1/4"- 1/8" or so.
The sealant will ooze out of the threads and will help seal around the four bores in the collar and the gasket area.
As for gear pattern and/or contact, if you want to you can take a back-lash reading before you pull it apart.
No need to check pattern with die unless you suspect an issue.
If you take up back-lash with the main drive gear, technically you should also take up some with the two driven gears.
This would mean reducing the shim value between the bearing retainer and gear case.
However, this changes the shim control both "Under" the transmission and "Between" the upper bearing and top cover.
For these two areas, what you remove from one side, must be added to the other!
I'd not worry about it unless you suspect an issue!
This sounds more complicated than it actually is. You'll do just fine.
