volvo_farmer
"I finally felt a little greas
"I finally felt a little grease on the bottom side of the U joint bellows before putting in yesterday. I think there's a little split on the underside of the bellows. I did the exhaust last year because it was easy but now it's time to do the drive bellows.
So I did some cursory searching of the board to find the general procedure for this job. Has anyone described it before in here and can find the post?
A few other things... How do I determine if the bellows is leaking water into the drive unit and how bad the leak might be?
I've likely only got 3 more days on the lake with this boat this season and perhaps 20 hours in the water, If the leak isn't too bad and I'm going to replace the u joints anyway, how bad of an idea would it be to run it as-is until the fall, when I can do the job at my leisure?
Thanks!"
Thanks!"
