roryrhodes
Things continue to go well, all the troubleshooting help - especially with HondaDudes help - has nailed issue after issue. Almost there.
The trim switch, under the motor, seems stiff. Doesn't spin and spring back to a neutral position. From my earlier thread, I get an intermittent beep from the warning buzzer, I think it has to be trim related. I'll assume - have not got close to it yet - that this trim switch springs under pressure when the motor is down, and follow the motor up due to the spring. It should not be stiff and non responsive, and it moves but sticks in one place when you move it by hand. Only had a couple of minutes tonight on the water to figure it out as it was getting dark. Thoughts?
19' Carolina Skiff, 12 pitch prop, 4600 WOT RPM, and 25 mph. = Next Challenge. I would like a little more speed.
