Did replacing the springs fix the problem?
-JJ
The bellhousing has a rubber flap held with a single 1/4 inch bolt.
Jeff
i only run with 1 tank on at a time i switch between
Mine I noticed is on tbe harmonic ballancer
This is where you'll need to look at your OEM specs. I'd not guess at this, I'd look up what the OEM recommends.what kind of max RPM's should I be seeing?
Good info!"4000 RPM WOT = heavily loaded engine
4400 RPM WOT = lightly loaded engine
Max cruise RPM 75 to 80% MAX WOT
Spoke to an engineer at Chrysler marine many years ago on this issue. Engine life a WOT is measured in hundreds of hours. Engine life at 80% WOT (as I recall) 2000 hrs... At 75% WOT climbs to 3000 hrs. (assuming FWC) All these hours assume engine can reach specified WOT RPMS
(closer to middle, the better)."
Bingo! As usual...... smart man!Yes; that boat should plane IF the motor is running properly. Either it is not, the prop is wrong, or the bottom is needing cleaning.
I suggest you put a timing light on it and see if you are getting full spark advance AND full retard; it's common for the advance mechanism in those distributors to stick. If they stick advanced--and someone times it that way--then you won't get full advane and the motor will be a dog at full throttle.
Jeff
1.... JP, you cannot check this manually.Jeff,
Bottom newly painted, timing has beem done t times but.i.dont know.that anyone was aware of what you were talking about.
1.... How can check mechanical advance manuelly?
2.... Id like to do that before i start prop shoping
Yes, that is Chrysler's VR style triggering ignition with a mechanical advance unit directly underneath the plate.This is the dist i have... is this a mechanical one?
The two flyweight return springs are always of two different spring tensions, and size appearance.Ok so the springs looked shot but there were to.diffrent sizes amd the larger one didnt.do.anything just moved freely. So I replaced one of them and noticed a significant difference. According to the instructions on the springs replacing both advances timing at 1600rpm instead of replacing one where ot advances at 2600... To me makes no sense
Simple and short answers.... YES and YES!Jeff,
Doesn't the advance operate the same regardless of engine load conditions? If he's getting rpms in neutral but not under load, would you still suspect distributor advance?
-JJ
Nine times out of ten, these spring kits are intended for automotive us, not Marine.i just replaced one spring since for some reason the instructions on the slring said only replace both for streeet racing didnt make much sense. mzybe tmmrw ill replace both. i lubed everything so it moves more freely. it got better just windering about the other spring
Agree!This thread is chaos. Let's stick to one person and one issue at a time so we can actually get something done.
