redsnapper386
guys i need some instructions on how to reset the timing on my 1987 350 a-1.the motor is not stock.has been rebuilt with -bored 30 over,flat tops,stock crank polished,stock heads shaved .010, cam is stock with a 400 lift.i upgraded to a marine gm hei dist.the hei is tuned with correct springs and wts.i took boat to river for a test run.with timing set at 10 deg the boat simply would not idle.i slowly advanced the timing until all was good,i checked with time light,and the line on harmonic bal was about 2 inches above the timeing tab. i figure the dist is off 1-tooth,or out 180. correct me if im wrong.before i go further,can i get #1 at tdc,and restab the dist with rotor pointing to # 1. or can someone give me better instructions. i even wonder if the balancer is slipping on the hub.the balancer is 1987,and was not replaced.my fault there. thanks in advance.
