Hi, I have a 1982 Renken 19ft with merc 120 4 cyl sn on motor 6155985, model MCM 120 153 cid
I would like to know if it has timing chain or is it 2 gears meshed, boat was running fine then stalled out and would not restart,called friend he put his boat in and pulled us back to dock. since then I got new circuit breaker, rebuilt carb, put electric fuel pump, new points cap wires plugs cond, new coil. it sometimes tries to start, has 135 pounds comp in all 4 cyls, so I want to check timing chain or gears are bad.
Thank you
Thank you
