JohannesDeVr
Hi, I bought a merc 60Hp 3 cyl 2 stroke, but cant get it to exceed 3000RPM under load. When in neutral I can get it to 4800 RPM. It should be able to do 5200 RPM.
Carbs has been cleaned,
Fuel lines cleaned
Fuel pump redone.
New spark plugs
When checking tbe crank idle and crank WOT timing this was according to soec 2 degree after and 24 degree BTDC. When running the motor at 3000 RPM in neutral I notice the timing to be 12-14 degrees BTDC. What would be tbe cause and how could this be rectified?
Fuel lines cleaned
Fuel pump redone.
New spark plugs
