"Hi. I have a 2001 Mercruiser
"Hi. I have a 2001 Mercruiser 4.3l 190hp motor. I am in the process of replacing the the propeller and hub assembly. I removed the nut, propeller and washer. I am now tring to remove the thrust washer but, it appears to be stuck to the shaft. Is there any special tool that is needed to remove the thrust washer or do I just need to keep pulling at it until it comes off? Also when it is replaced can I use a general marine grease to lube it (the same type I would use to lube my trailer wheels. The lube says marine grade but, not sure if I should have a special grease to lube the hub and shaft.
Thank you,
Rich"
Thank you,
Rich"
