settimo velo
I've decided to fit through transom exhausts on my twin V6 installation. I've familiarised myself with the contents of the Merc Manuals - block off plate installation, height of riser above waterline, angle of exhaust pipe etc. Merc do not say much on the subject and don't seem to provide much in the way of a product solution, apart from flaps? I think Merc suggest installing flaps on the pipe ends and water shutters in pipe, which I guess is a necessary precaution to protect the engine from potential water ingress. I was thinking of 4" i/d pipe, based on the rubber pipes that are fitted on the riser to elbow joint. However, this does seem like quite a big pipe and looking at the riser, there is an inner pipe of smaller diameter that could also be used?
If anyone can offer any advice on through transom solutions and point me in the direction of any recommended product that would be a great help. Thanks
