Thread lock on every bolt and screw
blink3477
Assembling my 1993 Evinrude E5
Assembling my 1993 Evinrude E50JETB tonight.
Shop manual calls for threadlocker on some screws but not all.
Follow the manual and torque to spec or blue all threads whether the manual calls for it or not?
Please advise.
"blue locktight,...on the scre
"blue locktight,...on the screws,before the carb...w/out FAIL......lower unit,...omc /brp gask seal....or--auto parts--aviation formagasket 'brush-in-lid' exact...same stuff..."
Crankcase cover flange screws?
Cylinder head screws?
Intake manifold screws?
Crankcase head screws?
Powerhead to exhaust housing mounting screws?
Manual doesn't specify...what would you guys do?
Thanks.
I'm using a torque wrench
I'm using a torque wrench and torquing them to spec...
Just wondering if I should slap blue on ALL fasteners or just the ones the manual calls for.
Is the threadlocker just to prevent intrusion or to fight vibration loosening the fasteners?
"keeps from vibrating loose,on
"keeps from vibrating loose,only....carb to intake,is an absolute ...use blue locktite there...other than that,....dont use...use the above av frmagask."
