"A buddy's boat munched so
"A buddy's boat munched some sterndrive lower unit parts. I have it all disassembled in my garage and need to find some cheaper than dealer parts
or its going to get too expensive to be practical (~$1000 just for mandatory parts). Hoping somebody that has sources for used parts or a trash boat that has that drive. Seems to be a lot of old boats back there where there is water on the east side.
Its the same as 1982-1986, OMC stringer drive, series 800 outdrive, lower unit (series 800 is those used with a V8) . The following stuff would be helpful for low prices.
OMC part number
forward gear 983141 (replaced by 435020)
forward gear bearings 389039
forward gear thrust washer 327669
forward gear thrust bearing 389042
shift rod 322941
shift rod coupling 322900
shift rod fork 322938
pinion bearing 387817
vertical drive shaft 982424 seals 982946 (kit)
pinion gear nut 314730
Please reply or email [email protected] with parts/help. Thanks."
OMC part number
shift rod 322941
