BigNiner19
2005 Honda BF225. Noticed that my motor does not pump water at idle very well, but does seem to pump well under way. This usually tells me the impeller needs replaced. I have not done this on this new to me Honda, but I figured I would ask a couple questions before I dive into anything.
Do the two thermostats effect the amount of water discharged out the tell tale? Even when I hook up the hose to the flush port, the stream coming out of the tell tale is weak, but better than engine running in the water at idle.
Anything else I should take into consideration? I plan to do the impeller soon as a precautionary maintenance, but was curious about the thermostats. Thanks.
