I wrote in a while back about "no fire". You where correct. I replaced the rectifier and stator, after testing. Also a new starting battery as the other was tested and found to be bad. As for popping the 20 amp fuse, i pulled the control box apart, no problems there. Can i attribute the fuse problems to the weak battery? Running for now, thank you again.
