I wanted to send a quick thank you to everyone that has tried to help me with my engine and viewed my post. I was losing power at wide open throttle and to make a long story short while attempting to replace the water manifold gasket today I noticed my number two and number three pistons are damaged. I would guess that that is the problem I’m having achieving full power at wide open throttle.
for those of you having a similar issue losing power at wide open throttle it may be worth a check. I had replaced just about everything on the motor fuel lines coils gaskets fuel pump plugs you name it I probably replaced it and it came down to number two and number three pistons. What’s odd is I had 110 to 115 psi on each cylinder so I guess don’t always take a compression test is absolute
