whaler_warner
I recently removed the coils from my M90a to test and following the FSM the primary coils all tested within specs but secondary coils all measured in the 6400ohms range against specs quoted of 3600-4800? I triple checked each coil and got the same result.
are these specs ok? I’ve had problems with power dropping when motor is warm and after high speed/load running which is why I wanted to check them hoping to find maybe one out of spec?
