Gotta add this, talking about uneducated.
When I was a teen dad had a 1955 or 56 10 hp Scott Atwater. I liked to fiddle with engines and liked boats and all even though we had to rent a boat to go fishing. Anyway, many times I'd start and run that engine for a bit sitting on the wooden bracket in the garage where we kept it. I had a 55 gallon barrel in the yard and sometimes, if running for any length of time I'd run it in there......water level high enough to splash out when I'd put it in gear and run at low rpms...well above the impeller. I wouldn't run it very long on the garage rack, but would run it dry none the less. Looking back, I can imagine what that impeller looked like but never, to my knowledge had an overheat problem.....no tell tale and no OT warning back then. The exhaust relief was a row of vertical holes on the back of he midsection and you could see water mist squirting out of them when running. The demise of the engine was on one day, running in a river on a little wooden john boat I built, I ran across slightly submerged.... cut off just below the surface enough to not see them till it was too late with the current water level that day....old, out of service railroad trestle wooden pilings. The midsection snapped in the center, like you cut across it with a recip saw and the only thing that kept the lower portion of the MS and LU intact was the shifter cable...similar to OMC 2 screw clamp on the upper and lower shift rod in the middle of the MS to get the LU off......was a long way paddling back to my camp site. Never repaired the engine.
