fayetteguy
"Looking at my manual, there s
"Looking at my manual, there should be two green leads coming from the coil itself and the red will be the "converted" DC power from the rectifier.
If you tap into the green, that should give you the signal you need for the Tach (typical of all Yamaha models).response from G.L. last year regarding where to hook up my tach
So i finally got a manual fro my engine and it says hook the signal wires from tach to the two green wires from the stator (which are the same ones on the rectifier) but do they want the signal wire and 12V wire or what bc the back of the tach only has a signal post, 12V post, and Ground post, so which two do you think they want?"
