"Hi,
Does a new Gimbal bear
"Hi,
Does a new Gimbal bearing come with the outer aluminium housing and metal band or do you remove bearing and reuse this part. Also is there any info available on fabricating a bearing installation tool and an alignment tool.
What holds the plastic grease tube into the gimbal bearing area. I had to heat the housing to remove the old bearing and the tube pulled out.
Any advice welcome, Thanks Peter."
"Hi,
