"could sure use smoe help moun
"could sure use smoe help mounting transom plate,
1.the 120 hp transom plate does not line up. I'am trying to bolt it up to the existing gimbal housing which ia a 1986 rinker with an alpha drive. and its existing gimbal housing. the bolts coming thru transom are in a different place. Does this mean that I have to use the older gimbal housing,fill,and redrill the holes that wont align?
2. Will the alpha drive spline go into the 120 HP coupler or will I run into problems there also? 3. Is the power trim wiring that runs thru the transom plate hard to replace? Its kinda frayed...Any help would be appreciated. Ray...
also?"
also?"
