I'm replacing my Dp-E lower unit with a DP-a (I think it's DP-A??), same gear ratio but longer vertical shaft. Does anyone know the part number I need to order that is the shorter coupler (splined sleeve) so that the DP-e upper and DP-a lower will line up?
Also will the same prop cone work just with the smaller bolt?
Thank you,
Simon
Thank you,
Simon
