behattedllama
I have two boats that I inherited. One is a 26' 1990 bayliner Ciera 2655. It has a 5.7 V8 alpha one and matching outdrive, but is suspected to have a cracked block.
The other is project that was started before my grandpa died-- it's a 79 glastrom that's been stripped of its deck and interior, but it had a complete engine failure after beaching (5 years ago or so?) and was swapped in by insurance with a rebuild. I'm told it's a Mercruiser Gen II 5.7 v8, but with a Mercruiser 260 exhaust, fuel, and ignition systems. It also has a matching outdrive.
Long story short, I want to move the Glastrom engine into the Bayliner and want to know what kind of trouble I should anticipate. I have two options-- pull the engine with all of its components attached from the Glastrom and drop it into the Bayliner (and swap the outdrives); or, if it would be beneficial and the components are compatible, I could pull them off of the Alpha One and replace the Mercruiser 260 components with the ones on the Alpha One.
Any advice is welcome, as this is my first engine swap.
